By default, SNMP LLDP traps are disabled on all ports. The default value for the interval between SNMP LLDP trap notifications is 5 seconds.
The traps are only sent for those ports that are both enabled for LLDP and have LLDP traps enabled.
configure lldp snmp-notification-interval seconds
If you want to send traps for LLDP MED, you must configure it separately. Use the enable snmp traps lldp-med {ports [all | port_list]} command to enable these traps.
